Scheung053
Mar 24, 2020Follower
OpenVPN help (client cannot connect)
So I thought this would just be a simple process. In the router, enable ddns and make one. Then enable VPN, download the software and configuration files. Then place those files in the config folder....
Christian_R
Mar 26, 2020NETGEAR Employee Retired
Hi Scheung053,
Please refer to page 129 of the user manual for further information on setting up OpenVPN.
http://www.downloads.netgear.com/files/GDC/RAX40/RAX40_UM_EN.pdf
Christian
