Dboelling
Mar 25, 2021Tutor
OpenVPN will not work with RAX45 router.
Just baught an RAX45 router. Trying to get OpenVPN to work. Keep getting WARNING: No server certificate verification method has been enabled and TLS Errors. Windows 10. I tried multiple versions...
Christian_R
Mar 29, 2021NETGEAR Employee Retired
Hello Dboelling,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- DboellingMar 30, 2021Tutor
I contacted your support. They were AWFULL! Several different support persons that only wanted me to run through the same instructions and scripts multiple times. Then the support person told me that the VPN on the router woouldn't allow me access to my home network with OpenVPN anyway. That is only allows access to the router settings. Having been in IT and the Network Security Officer for several fortune 100 companies and having set up several Linksys and ASUS routers for home access for friends, I knew she was full of crap. The software and instructions on this router were for OpenVPN version 2.3 from 2017. We are now at 3.0. Another issue I had with this router, is that anytime a WiFi device connected it took between 1 and 3 minutes for the router to decide to connect the device to the Internet. Sorry, I took it back for a refund and went with an ASUS router. Set it up fine no issues in 10 minutes.
