Jockyboy49
Jan 14, 2021Follower
ORBI RBK 753 Purchase
My existing installation is Virgin Router operating as Modem only into a Nighthawk R7000 Router. I have additional ICU's or WAC,
I have made the Ordbi purchase to replave the Nighthawk Router.
Should I disconnect the Nighthawk completely before I install the ORBI system.
I feel the installation from Orbi App is puching me to install alongdie to learn about other devices?
Confused and need help please?
1 Reply
I would disconnect the nighthawk entirely for setup.
Its much higher performing than the R7000 and there's nothing like a fresh setup/rebuild of the network. :)
You could always connect the r7000 back later (in access point mode) if you wanted it for backup or for using for IoT devices.
