WouterVerlinden
Nov 09, 2021Follower
Orbi RBK854 versus 4x EAX80
Hi, is there any real difference between Orbi RBK854 and 4x EAX80? I will NOT be using Wireless connection between the access points / extenders. I will use a wired backhaul to each of the 4 ...
Nov 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Extenders won't have a dedicated wireless or wired backhaul connection like the Orbi systems have.
Thank you
