wifi6routers
Sep 22, 2019Aspirant
Orbi Wifi 6 vs RAX200 with EAX80
Can anyone provide a basic summary of pros and cons of each system. What would be the benefits of Orbi Wifi 6 setup vs a RAX200 (tri-band) with EAX80 mesh extender (other than the $150 price diff...
Altsai
Oct 02, 2019NETGEAR Expert
wifi6routers wrote:Can anyone provide a basic summary of pros and cons of each system.
What would be the benefits of Orbi Wifi 6 setup vs a RAX200 (tri-band) with EAX80 mesh extender (other than the $150 price difference)?
>>>> if one router can cover all areas you'r going to use, RAX200 is your best choise. if your application requries additional wifi range extender, either Orbi system or RAX200 + EAX80 could fit your need but honestly, which one is the best for you will requires real test in your house.
avtella
Oct 03, 2019Prodigy
If going for a single router without needing extenders the RAX120 is a better choice than the RAX200 mainly due to the WiFi chipset, Broadcom looking at previous gen didn’t do a great job of implementing ancillary features like MU and Broadcom based devices have had issues with MU enabled causing lower performance and Broadcom routers with 1024QAM on AC did worse than Qualcomm based routers using 256 QAM in terms of peak performance. Qualcomm in my opinion implements advertised features in a more functional manner. Hence the reason I’d pick the RAX120 over the RAX200. Only get the RAX200 if you need to add an extender because then the extra 5Ghz band can be used for backhaul. Just know that higher model number isn’t necessarily better, just look at the performance reviews comparing R7800 (Qualcomm based dualband) vs the R8500 (Broadcom based chipset triband).
