wifi6routers
Sep 22, 2019Aspirant
Orbi Wifi 6 vs RAX200 with EAX80
Can anyone provide a basic summary of pros and cons of each system. What would be the benefits of Orbi Wifi 6 setup vs a RAX200 (tri-band) with EAX80 mesh extender (other than the $150 price diff...
psychopomp123
Nov 04, 2019Luminary
OP,
I purchased the RAX200 to replace my Linksys EA9500v2 (also a tri-band router). I have a tonne of wifi devices so wanted to stick with a tri-band router as I can allocate devices accordingly. I'm finding 802.11ac speeds on the RAX200 even better than the Linksys and overall, the RAX200 is a brilliant router for wifi range. The RAX200 isn't cheap but if you're looking for a tri-band router and you can afford it, then I highly recommend it!
