texaggie1994
Jan 28, 2023Aspirant
Orbi With Nighthawk AX6
I have Orbi RBR40 with 3 satellites installed and if works wonderfully, except for inside my metal shop building. The satellite is mounted on the wall outside of the building, but inside the signal ...
Jan 28, 2023Guru - Experienced User
What is the model# of the AX6? EAX##?
- texaggie1994Jan 28, 2023Aspirant
RAX49
- FURRYe38Jan 28, 2023Guru - Experienced User
Try putting the RAX in AP mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
I am learning as I go, I changed it to AP and selected choose IP address dynamically from existing router.
Do I also change the wireless settings to match the SSID and password of the main Orbi Router?
