texaggie1994
Jan 28, 2023Aspirant
Orbi With Nighthawk AX6
I have Orbi RBR40 with 3 satellites installed and if works wonderfully, except for inside my metal shop building. The satellite is mounted on the wall outside of the building, but inside the signal ...
texaggie1994
RAX49
Jan 28, 2023Guru - Experienced User
Try putting the RAX in AP mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- texaggie1994Jan 28, 2023Aspirant
I am learning as I go, I changed it to AP and selected choose IP address dynamically from existing router.
Do I also change the wireless settings to match the SSID and password of the main Orbi Router?
Thank you for the advice, will AP mode be much slower than router mode?
- FURRYe38Jan 28, 2023Guru - Experienced User
Would be same or a bit faster since it doesnt' have to do any router functions. Best speed will depend on devices and the connection rate and condition between the RBR and RBS if you connect up this AP. Be sure channels are far appart from what the Orbi uses.
