Rac200
Jul 26, 2021Tutor
outside extender AC3000 connect with ax11000 (rax200)
I have the router rax200. I want to have better internet outdoors, so I am thinking of buying the outdoor extender AC3000. Can these two work together or is there a better solution? Like to hear. Tha...
michaelkenward
Jul 26, 2021Guru - Experienced User
AC3000 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
If you mean the RBS50Y. check the manual for the various modes.
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Rac200
Jul 26, 2021Tutor
OK thanks. I found these for outdoors https://www.netgear.com/home/wifi/mesh/rbs50y/. do you think this can be used with the rax200?
- michaelkenwardJul 26, 2021Guru - Experienced User
Should work.
Try this:
Can I use an Orbi satellite with my existing router? | Answer | NETGEAR Support
Orbi RBS50Y - Mesh WiFi Range Extender | NETGEAR
- plemansJul 26, 2021Guru - Experienced User
If you have an option of hardwiring it in, there's also things like the WAX610Y (outdoor AP) that you could utilize outdoors.
https://www.netgear.com/business/wifi/access-points/wax610y/
- Rac200Jul 26, 2021TutorThanks
