Rac200
Jul 26, 2021Tutor
outside extender AC3000 connect with ax11000 (rax200)
I have the router rax200. I want to have better internet outdoors, so I am thinking of buying the outdoor extender AC3000. Can these two work together or is there a better solution? Like to hear. Tha...
Rac200
Jul 26, 2021Tutor
OK thanks. I found these for outdoors https://www.netgear.com/home/wifi/mesh/rbs50y/. do you think this can be used with the rax200?
michaelkenward
Jul 26, 2021Guru - Experienced User
Should work.
Try this:
Can I use an Orbi satellite with my existing router? | Answer | NETGEAR Support
Orbi RBS50Y - Mesh WiFi Range Extender | NETGEAR
