tinizong's avatar
Aug 19, 2021
Package loss with RAX200
Hi everybode.
I bought the Nighthawk RAX200 router. The modem of the ISP (Gigabox UPC) is set to bridge-mode and the router is connected to the PC via a Cat 6 Ethernet cable.
In this setup I have regular stutters and package losses in online games (Valorant, CoD:Warzone, World of Warcraft), which make playing impossible.
I have now deactivated the bridge mode on the modem of the ISP (Gigabox UPC) and connected the PC directly to the modem with the same cable. The Netgear router is now in AccessPoint mode. The interruptions are no longer noticeable.
I had hoped for more from the product and could have bought a dedicated AP. I would also like to use the other functions that the router offers. VPN server etc.
How can I fix my problems with the package losses?
With kind regards
  • Hi all
    I head contact with the Support and they adviced me to set the Internet IP from "Provided by ISP" to "Static IP". That worked so far. I will keep an eye on this topic.
    Cheers.
1 Reply
  • Hi all
    Cheers.
