Dazzwater
Mar 13, 2020Tutor
Parental controls for Nighthawk or Orbi Wi-Fi 6 routers?
Does the MK62 — Nighthawk Mesh WiFi 6 System have parental controls? If so, is it through Circle or the Genie app or something else? If not, why not? Is it in the works and when will it be availabl...
Mar 13, 2020Guru - Experienced User
If not, why not? Is it in the works and when will it be available?
Same question for the Orbi Wi-Fi 6 router.
Netgear doesn't release dates for when changes are going to be implemented. I have a feeling its in the works because its a revenue steram for netgear. Problem is that wifi 6 was a totally new standard and so netgear has been getting the basic functionality running right first. And then they add in features.
- DazzwaterMar 13, 2020Tutor
I need parental controls. What is my best option now:
1. wait for it to be available on the RBK852 Orbi WiFi 6, or
3. buy the Circle Plus device (assuming it works with the RBK852) for $299, or
2. return my Orbi WiFi 6, and buy an older router for eg RBK50 which is supported by Circle?
- plemansMar 13, 2020Guru - Experienced User
Dazzwater wrote:I need parental controls. What is my best option now:
You're best option is to see what you need. If you NEED a router right NOW with those options, then you'll either need option 2 or 3.
Again, I'm pretty sure its in the works but netgear doesn't release dates so its hard to know a timeline on how long.
- EchostormFuryJun 06, 2020Apprentice
I use the Circle Plus with the AX6000 Orbi routers. There are some compatibility issues that I hope netgear addresses.
- MarifpJun 07, 2020AspirantI recently switched my router to Orbi wifi6 rbr850 and ended up buying circle home plus for parental control but I could not get it to work. The app said paring was successful but there was no single device that I could see. I tried phone circle support but no live person because of covid-19?? Has anyone successfully paired those two devices, circle home plus and orbi WiFi 6, to work? Please help!!
