Dazzwater
Mar 13, 2020Tutor
Parental controls for Nighthawk or Orbi Wi-Fi 6 routers?
Does the MK62 — Nighthawk Mesh WiFi 6 System have parental controls? If so, is it through Circle or the Genie app or something else? If not, why not? Is it in the works and when will it be availabl...
Dazzwater
Mar 13, 2020Tutor
I need parental controls. What is my best option now:
1. wait for it to be available on the RBK852 Orbi WiFi 6, or
3. buy the Circle Plus device (assuming it works with the RBK852) for $299, or
2. return my Orbi WiFi 6, and buy an older router for eg RBK50 which is supported by Circle?
Mar 13, 2020Guru - Experienced User
Dazzwater wrote:I need parental controls. What is my best option now:
You're best option is to see what you need. If you NEED a router right NOW with those options, then you'll either need option 2 or 3.
Again, I'm pretty sure its in the works but netgear doesn't release dates so its hard to know a timeline on how long.
