Dazzwater
Mar 13, 2020Tutor
Parental controls for Nighthawk or Orbi Wi-Fi 6 routers?
Does the MK62 — Nighthawk Mesh WiFi 6 System have parental controls? If so, is it through Circle or the Genie app or something else? If not, why not? Is it in the works and when will it be availabl...
Dazzwater
Mar 13, 2020Tutor
I need parental controls. What is my best option now:
1. wait for it to be available on the RBK852 Orbi WiFi 6, or
3. buy the Circle Plus device (assuming it works with the RBK852) for $299, or
2. return my Orbi WiFi 6, and buy an older router for eg RBK50 which is supported by Circle?
EchostormFury
Jun 06, 2020Apprentice
I use the Circle Plus with the AX6000 Orbi routers. There are some compatibility issues that I hope netgear addresses.
- MarifpJun 07, 2020AspirantI recently switched my router to Orbi wifi6 rbr850 and ended up buying circle home plus for parental control but I could not get it to work. The app said paring was successful but there was no single device that I could see. I tried phone circle support but no live person because of covid-19?? Has anyone successfully paired those two devices, circle home plus and orbi WiFi 6, to work? Please help!!
- EchostormFuryJun 07, 2020ApprenticeI could get it to work but you need to set circle to compatibility mode on the circle app settings then reboot circle. You have to do this off and on to get it playing nicely with the Orbi Wifi 6 platform. I wish they would update their firmware to make it more compatible
