Brjones505
May 31, 2021Follower
Parental controls not working
I bought this router for the parental control and have my kids profiles set up with their devices assigned to them. I can see how much time they are using each day and i get notification when they hi...
Dubbz4life
Jul 14, 2021Initiate
I'm having the same exact issues as you with the rax45, and more than likely anyone else that has this model. I bought one about a month ago and it had the same issue, so I returned it. I decided to try it one more time, hoping that I just had a defective unit and nope. It still doesn't work. I'm now on hold with tech support {20 minutes now) to see if there's actually a fix. Im sure this is a waste of my time and this thing will be going back again.
- Christian_RJul 19, 2021NETGEAR Employee Retired
Hello Dubbz4life,
Welcome to the community! Were you able to get in touch with our support team regarding your issue(s)?
Christian
- Madbrad70Jul 20, 2021Tutor
No, still have the same issue. My router is no longer under warranty so ill just keep using until im ready to buy a different brand.
- Christian_RJul 21, 2021NETGEAR Employee Retired
Hello Madbrad70,
What is the model number of your router?
Christian
Did you by chance get anything figure out with tech support?
Dubbz4life wrote:
I'm having the same exact issues as you with the rax45, and more than likely anyone else that has this model. I bought one about a month ago and it had the same issue, so I returned it. I decided to try it one more time, hoping that I just had a defective unit and nope. It still doesn't work. I'm now on hold with tech support {20 minutes now) to see if there's actually a fix. Im sure this is a waste of my time and this thing will be going back again.- Dubbz4lifeJul 22, 2021InitiateNo. I spent literally an hour on the phone. I was passed around 4 TIMES and then the last person I talked to hung up on me when I told her I was having issues with parental controls. She also had confirmed my contact number but still never called me back. My guess is that netgear knows this is an issue and that there is currently no fix. This is the last time I will buy a netgear product. The last 3 units I've purchased all have had major issues and I've never had good experience with their customer service each time. Netgear at one time produced good products. Not so anymore.
- Christian_RAug 03, 2021NETGEAR Employee Retired
Hello Users,
Can you confirm that you are on the latest firmware version for the RAX45 listed below.
https://kb.netgear.com/000063828/RAX45-Firmware-Version-1-0-3-96
Christian
