Txtech77
Dec 11, 2020Guide
Pause device internet AX6000
Why are we still not able to pause internet to devices for the RBR850? It worked when I first purchased the Orbi system but has not worked in Months! Are they ever planning to fix this?
Txtech77
Dec 12, 2020Guide
Are you talking about anywhere control? Can’t seem to get that to work properly either. I’ve read other posts I’m not the only one with this issue. You find the device you want to turn off internet to and click the switch to off but it won’t shut off anything streaming to the device. Only makes it so that the device can’t get new content basically. That is an improvement over not shutting anything off like before but it’s still not full control over internet.
michaelkenward
Dec 12, 2020Guru - Experienced User
I was thinking of access control.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Control Access to the Internet.
You may have done this already. I can't tell from your message.
I thought that was what you had tried and failed to get working. Then again, I can't tell from your message what you were using to "pause internet to devices" and what happens when you try it. So we are left guessing as to what might be going wrong.
By the way, in its wisdom, Netgear has slapped the label "Anywhere access" to what we once knew as "Remote access".
- Txtech77Dec 12, 2020GuideI’m using the Orbi Netgear app. Inside that app you can name devices and each one has a toggle switch to pause/resume internet. That is what I am using. I have not done anything with access control.
