hoshposh
Apr 18, 2023Follower
PC download speed is slower then speed provided by ISP
I recently upgraded my home internet and purchased a Nighthawk router to go along with it. After setting everything up with my ISP and the Nighthawk, I used the app to test the speed and it showed ar...
Apr 18, 2023Guru - Experienced User
You've gave us not much to go off.
1. what router did you buy?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. how is your PC connected to the router? Wired? Wireless? What band?
5. what are you using to speedtest with?
