hoshposh
Apr 18, 2023Follower
PC download speed is slower then speed provided by ISP
I recently upgraded my home internet and purchased a Nighthawk router to go along with it. After setting everything up with my ISP and the Nighthawk, I used the app to test the speed and it showed ar...
Kitsap
Apr 18, 2023Master
hoshposh wrote:I recently upgraded my home internet and purchased a Nighthawk router to go along with it. After setting everything up with my ISP and the Nighthawk, I used the app to test the speed and it showed around 700 Mbps. My set up is in the basement of my house and the router is set 2 stories higher. When using my xbox the download speeds match the speed provided by my ISP but when I use my PC the speeds are significantly slower. I checked my ethernet settings and it says my Link speed is 1000 Mbps, but when testing my download speed it averages 30 Mbps. My question is, would this be a router problem (the location or maybe a setting I can change) or is this a problem with my PC's hardware?
Like plemans says, your post is really sparse on details.
If you have a Windows computer, your computer treats your new router like a new network. As a protective measure, Windows sets the profile for new networks as public like you are connecting in a coffee shop or restaurant. Go to Network Settings and make sure your Network Profile is classified as private and not public.
michaelkenward
Apr 19, 2023Guru - Experienced User
Wise advice. That's an "oldie but goodie" around here.
It isn't always easy to track down as Microsoft "improves" things.
In Windows 11, look in
> Settings
> Network & Internet
