Paulie1201
Sep 04, 2020Tutor
Performance issues with the CAX80
I purchased the CAX80 and I have had nothing but issues with it. The WiFi fails daily, and I am forced to reboot it. I never get my Gigabit speeds, even when I hardwired into the router. I am quick to...
Sep 04, 2020Guru - Experienced User
Do you have a screen snip of the cable connections page? And the modem logs?
Those help check the connection.
If you have any splitters, amplifiers, attenuators in your coax line, remove them.
Also try logging into the debut page: should be ip address/debug.htm so 192.168.1.1/debug.htm (or whatever you set for the ip address)
make sure the "enable lan/wan packet capture" isn't checked.
Paulie1201
Sep 04, 2020Tutor
Attached is the screenshot of my cable connection page. Also, I tried the debug page and nothing happened. I unchecked "enable lan/wan packet capture."
- plemansSep 04, 2020Guru - Experienced User
your screen shot didn't tell us anything. You need the 32 channels downstream info, the upstream, and the ofdma channels and the logs.
- Paulie1201Sep 04, 2020Tutor
Here you go.
And you logs?
What speeds you get hardwired?
Are you using dfs channels?
Is it all devices having issues? Just wired devices? just wireless devices? both?
What settings are you using for your wifi?
