tbeiswenger
Apr 18, 2024Tutor
Performing hardware diagnostic on Nighthawk RAX50
I am trying to determine cause of slow and intermittent internet access. ISP test showed that their cable modem is working correctly and suggests that I do a diagnostics test on my router. When I log...
Apr 19, 2024Guru - Experienced User
The modem model is important. The label should have it on it.
Are you sure you don't have an RAX48? The RAX48 has that firmware version on it but no either V1 or V2 of the RAX50.
Is it only the one device with issues? You say streaming on a tv. What tv? is it streaming on a roku/apple tv or what are you using for streaming?
Are you on the 2.4ghz or 5ghz while streaming?
How far from the router is the tv with issues? And what is between the 2? (walls/appliances/etc)
tbeiswenger
Apr 21, 2024Tutor
I am absolutely sure that the Router is an RAX50, which is what appears on the router's label.
We see the internet issue only on our main TV which is a Sony Google TV less than 2 years old. We have other older TVs in the house that are not used very often, so we do not know if the issue also appears on them.
I don't know how to determine whether the TV is on the 2.4ghz or 5ghz while streaming. Both of the indicators for these on the router are always illuminated. The router is in a second floor room, less than 20' from above the TV on the first floor. The only thing between the router and TV is the floor and open staircase.
There also is a Netgear extender (AC750 WiFi Range Extender Model EX3110) less than 10' from the TV.
- plemansApr 22, 2024Guru - Experienced User
guess you do have the RAX50. Must be a pre-release version or you got an earlier version.
If only 1 tv is having the issues, I tend to look closer at the tv.
A couple things.
1. Don't connect the tv to the extender. Extenders drop throughput (speed) and increase latency. Which makes tv's buffer more
2. You should be able to log into the tv and see what band its connected to. Most tv's have a way to do so. You should also be able to log into the router through the browser and check if its on the 2.4ghz or 5ghz on the attached devices page.
This is a little key as 2.4ghz is a low network and sensitive to interference. The TV should be on the 5ghz, provided its close enough and doesn't have to much material in the way (certain materials do a great job of blocking wifi).
3. Have you noticed a difference in what its streaming? What I mean by this is live tv struggles more with speed/interference/latency than something you stream from netflix/youtube. The reason why is life tv doesn't have as much streaming buffer (can't load information ahead of time). So they're more sensitive
- tbeiswengerApr 23, 2024Tutor
Pretty sure that it is not the TV. Last time the slow wifi occurred, we turned off the TV and cycled power to it. When we returned to streaming, the latency was still a problem. We see the latency when are streaming from Netflix and Amazon Prime.
I checked the devices tab of the router. It show all non-wired devices (including the Sony TV) connected at 2.4Hz. How do I change that? I though that the router was supposed to automatically connect at the fastest speed available.
Though the extender is in the same room as the Sony TV, the wifi connection page on the TV shows that it's connected directly to the router and not the exender.
- plemansApr 24, 2024Guru - Experienced User
If the extender and the tv are in the same room, don't use the extender. It'll lower speeds and increase latency if its in the same room.
What tv model is it? Some only had 2.4ghz. I had some relatives who recently ran into this when their 1st Generation 4k smart TV wasn't so smart and was slow/buffering all the time. They thought they needed to replace it. I simply had them buy a Roku or Firestick that supported 5ghz and had a newer processor. Works fine again. Might be something to check into if the tv supports 5ghz or if its getting older. Or even using a different extender but one that supports ethernet and is faster than the ex3110 (its a base model, slow extender)
