simonpollayil
Jul 11, 2020Tutor
Persistent connection issues with Apple HomePod
So I am having consistent issues with playing music through my HomePod via my phone (iPhone Xs) or my laptop (MacBook Pro), the issues crop up in two ways: I try to connect via airplay and it start...
Christian_R
Jul 15, 2020NETGEAR Employee Retired
Hi simonpollayil,
I would check to see if the router is due for a firmware update.
Christian .
simonpollayil
Aug 09, 2020Tutor
I actually solved the issue by rolling back the firmware to v1.0.2.60_1.0.1. This is unfortunate because I don’t have the latest security updates but it was between that or being able to use my devices
- hexixninAug 09, 2020Aspirant
Rolling back?? :smileymad::smileymad:
I will try.
It seems that cannot upgrade the firmware casually :smileylol: :smileylol:
- simonpollayilAug 09, 2020Tutor
I’ve detailed the process in this Reddit comment :)
https://reddit.com/r/HomePod/comments/hp3za0/_/fz7kk7v/?context=1- hexixninAug 09, 2020Aspirant
thanks
if I knew this bug,I didn`t change my R6120 to this route.:smileyfrustrated:
