gcalli
Jun 25, 2024Apprentice
Persistent Issues with Netgear RAX43 5GHz Network and Log Settings
Hello NETGEAR community, I've been experiencing recurring issues with my NETGEAR Nighthawk RAX43 router, specifically related to the 5GHz wireless network and log settings. Despite trying various t...
gcalli
So true.
Point taken - was planning to but forgot.
Firmware version: V1.0.16.132_2.0.92
Modem/ONT: raisecom.com
ISCOM HT803G-1GE (M)
It's not a router doesn't have LAN ports - only one to connect to router
Thanks for the advice.
gcalli
Follow up feedback:
After working seamlessly for 10 hours, it stopped working again.
- gcalliJul 27, 2024Apprentice
@Marc_V
Could you assist please?
I have an open Level 2 case that I would like to escalate to Level 3 and have a different support agent take over.
The current support agent argues that for my 5G wireless network on the RAX43 to work properly, I should use the 5G only when in the same room as the router, ideally within 3-meters or less. Additionally, she mentioned that walls in my house are the problem.
However, with my previous NETGEAR Router the R7000, the 5G connectivity was seamless throughout my entire house.
Thanks
- FURRYe38Jul 27, 2024Guru - Experienced User
The people you attempted to tag are no longer at NG.
Best to keep in contact with NG support thru your support ticket.
- gcalliJul 28, 2024Apprentice
Thanks. Will do.
I need to resolve this issue as soon as possible. Otherwise, as time flies' and inconveniences mount, the warranty period may expire before the issue has been resolved!
