cschoepf3
Oct 04, 2022Aspirant
Physical width of RAX50 or RAX54S
Does anyone know the physical width of the RAX50 or RAX54S router? Netgear documents it at just under 12 inches wide but Tom's Hardware's page lists it at 14 inches wide. I'd like to confirm before...
Oct 05, 2022Guru - Experienced User
The fcc's got pretty good photos on a ruler. but its without the antenna's attached. I'd take a look through if you need specifics.
https://fccid.io/PY319400466/External-Photos/External-photos-4570522
looks like around 28cm (ish). so roughly 11 inches.
- cschoepf3Oct 06, 2022Aspirant
Thanks for the information. I think with the antenna's attached, it'll be too wide for it's intended location. I appreciate your time.
