MGorgol
Dec 15, 2019Star
Poor Signal - Need Options
Purchased my RAX80 some time ago. Been pretty happy with it except for the random internet dropping issue. However, I have paired it with an X6S to extend out to the backyard and eventually to a gues...
- Dec 16, 2019
like GabboCH said, a cable would be the best solution.
You're other option I'd look into would be a system designed for what you're trying to do. They're called a point-point system. They use a directional antenna and need to be aimed at each other. But they have a much better signal and get much less interference. If you're trying to go any distance outdoors and can't hardwired it, a system designed for what you're trying to do is going to work better than rigging it up. Especially if its a guest house that needs a stable connection.
Just my 2 cents.
Dec 16, 2019Guru - Experienced User
Just my 2 cents.
- MGorgolDec 16, 2019Star
Thank you. I will definitely look into that. The guest house won't be finished for about 5 months so I may wait on implementing any solution as there may be available 5G solutions where I could have two separate accounts - the cost of which (for both) would still be about half what I'm paying now for one account.
