jackjuljay
Apr 04, 2023Aspirant
port forward not working on port 25565
So i decided to Make a Minecraft server i have port forwarded 25565 tcp and udp i also have allowed the ports through firewall i have been running the server and cant seem to have anyone join I...
birgsmitchyl
There could be several reasons why your Minecraft server port is still closed even after you have port forwarded and allowed the ports through your firewall:
Double check your port forwarding settings: Ensure that you have correctly set up port forwarding on your router. Double check that you have forwarded port 25565 to your server's local IP address.
Check your firewall settings: Make sure that your firewall is allowing inbound and outbound connections for port 25565.
ISP blocking the port: Some ISPs block certain ports for security reasons. Check with your internet service provider to make sure that they are not blocking port 25565.
Router blocking the port: Some routers may have a built-in security feature that blocks incoming traffic on certain ports. Check your router's settings to see if it is blocking port 25565.
Incorrect IP address: Make sure that you are providing your friends with the correct IP address to connect to your server. You can find your public IP address by doing a quick search on Google for "What is my IP address".
Minecraft server software settings: Double-check that the Minecraft server software is configured correctly to use the correct port.
- jackjuljayApr 05, 2023Aspirant
Thankyou for the help i was wondering if i would need to port forward through my modem first for the connection to work i am using an xfinity XB6 modem and plugin it into the router would i need to port forward on their first to get the connection to open on the router side or would this not matter
- michaelkenwardApr 06, 2023Guru - Experienced User
jackjuljay wrote:
..... i am using an xfinity XB6 modem and plugin it into the router
That looks like a "gateway", a device that combines modem and router. So you are piling router on router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
It is also likely to complicate your attempts at port forward.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.Using Bridge Mode On Your Wireless Gateway - Xfinity Support
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support - FURRYe38Apr 06, 2023Guru - Experienced User
Disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
Then check the port forward configuration on the NH router.
also is there another port i could port forward for a Minecraft server
