stevengates45
Dec 18, 2020Tutor
Port Forwarding after Dumb Switch Bypass Completed
I have an RAX48 router and ATT 1Gbps service. I’ve completed the Dumb Switch bypass and it works great. I still have one problem though. I can’t seem to get the RAX48 to successfully setup port forwar...
- Jan 24, 2021Update: I reset the router and it works now. I had performed multiple resets in the past without success but for some reason it fixed my problem this time. Who knows, just glad it works now!
Christian_R
Dec 23, 2020NETGEAR Employee Retired
Hello stevengates45,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- stevengates45Jan 24, 2021TutorUpdate: I reset the router and it works now. I had performed multiple resets in the past without success but for some reason it fixed my problem this time. Who knows, just glad it works now!
