lxstasy04
Feb 15, 2024Aspirant
port forwarding ax5400
sorry if this has been asked before hope someone will be kind enough to help. i have a synology nas ds415+ that i run a plex server off of. I try to set up remote access for this by forwarding...
lxstasy04
ok thanks for the reply but why would i contact plex because i cant get the port to actually open or forward on my router and modem? i put the port forwarding rule in my router but when i go to check the port its not open.
Feb 15, 2024Guru - Experienced User
You have to be sure that what ever device is configured is actively using the port.
Also be sure to disable uPnP on the router as well before setting up any PF rules.
Set a IP address reservation as well for the device being configured for PF rules:
https://kb.netgear.com/24092/How-do-I-edit-a-reserved-IP-address-entry-on-my-Nighthawk-router
Again, something to ask the device mfr about as well as they will know how to configure a router for PF rules.
