SLal's avatar
SLal
Follower
Dec 20, 2020
Port forwarding not working
I replaced old wifi router with RAX45 , AX4300 and port forwarding stopped working
not able to access web pages from internet
Please suggest steps
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello SLal,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
  • I can't get a list of already forwarded ports. When I try to redirect a port it says denied or port conflict. If I had a list of what has been redirected, it would  be easy enough to delete, but this router does not have a human friendly interface.
    HOW DO I GET A LIST?????
  • Did you ever get a solution? I was able to port forward for WRDP but I can’t port forward anything else.
