wendyjm
Oct 19, 2021Aspirant
Port Forwarding Not Working
I have a Netgear CM1200 modem and a Netgear Nighthawk RAX80 router. We use Xfinity for our ISP. I have a minecraft server set up with a static IP that works properly when on the same network. I ha...
Oct 19, 2021Guru - Experienced User
Do you have uPnP disabled if you have the PF configuration in place?
Are you actively using the port prior to checking port status?
- wendyjmOct 19, 2021Aspirant
The server on the port is active.
I disabled the Ubuntu firewal (sudo ufw disable) if that is what you mean by upnp
