SniperStorm
May 22, 2022Tutor
Port Forwarding rules disappearing!! 2022 Version!
Today I noticed that you could not access my telnet port from the outside. I looked at my port forwarding rules and they are all BLANK!( I will ad screen shots). If I goto try to add them again you...
CD_router_888
May 24, 2022Guide
Hi SniperStorm
What is the FW version you use ?
SniperStorm
May 26, 2022Tutor
V1.0.10.82_2.0.39 Is my firmware version. It does not even matter. This issue seems to have been going on for years for many people on many netgear routers. I have to reload a saved config to be able to see the ports again,
- JenniferMathisOct 19, 2022Aspirant
Is it solved?
- SniperStormOct 19, 2022TutorIt has. Not been resolved. Netgear sends me beta firmware that never fixes it. I actually believe is interface is causing the problem with the web browser. Like it's programmed incorrectly. It's been 6 months and no fix. I brought a linksys 6e and it's working trouble free. Said bubbye to $500
R.I.P $500
