akhan999
Jan 02, 2024Aspirant
Port forwarding settings disappear RAXE500
I noticed by PBX server was no longer visible outside of my home network. Looking further into I noticed Port Forwarding / Port Triggering settings were no longer visible in the Netgear UI. I resta...
Jan 02, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is uPnP disabled while the PF configuration is enabled?
Try the PBX service device in the DMZ on the RAX instead of using PF configuration?
akhan999
Jan 03, 2024Aspirant
Hi,
- Firmware V1.2.13.100_2.0.54 Maybe this caused it worked fine before this.
- ADTRAN sdx611 GPON ONT
- Using the cable they provided
- UPnP is enabled
- Not keen on using DMZ.
- FURRYe38Jan 03, 2024Guru - Experienced User
Disable uPnP if you have any PF configurations enabled...then check.
