akhan999
Jan 02, 2024Aspirant
Port forwarding settings disappear RAXE500
I noticed by PBX server was no longer visible outside of my home network. Looking further into I noticed Port Forwarding / Port Triggering settings were no longer visible in the Netgear UI. I resta...
akhan999
Jan 03, 2024Aspirant
Hi,
- Firmware V1.2.13.100_2.0.54 Maybe this caused it worked fine before this.
- ADTRAN sdx611 GPON ONT
- Using the cable they provided
- UPnP is enabled
- Not keen on using DMZ.
Jan 03, 2024Guru - Experienced User
Disable uPnP if you have any PF configurations enabled...then check.
