Macmanlex
Mar 02, 2020Aspirant
Port Forwarding settings (RAX75)
For some reason I cannot see change or add to my port forwarding on my RAX75. When I try to add a forwarding port the page fails. I turned of UPnP and no change. This is really messing up my useab...
Macmanlex
May 07, 2020Aspirant
Isn't anyone monitoring these threads? I have gotten no response in a month!!
Christian_R
May 08, 2020NETGEAR Employee Retired
Hello Macmanlex,
May you factory reset the router and run through the setup assistant again. This has worked for others as mentioned in a separate thread.
Thanks,
Christian
