waltisbadical
Nov 15, 2021Follower
Port Forwarding Turning Off on RAX200
I know many people have had this issue, but when I turn on Port Forwading everyhting is fine. But when I don't use it for a week and come back it is closed. So, I have to delete the port forwarding and reset it up. It's not that this is difficult but it's just fustrating. Does anyone have any fixes or ideas? Maybe someone from Netgear????
1 Reply
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Check FW version and a factory reset and setup from scratch since last FW update?
Also please give ISP modem/ONT information as well.
Thank you.
