cyberwasp
Jun 20, 2022Star
port forwarding
Nighthawk RAX50 Firmware Version V1.0.11.112_2.0.77 I have a Synology NAS connected to my Nighthawk RAX(50) . I'm currently trying to set it up for connect from outside of my home via ddns. Howe...
Razor512
Jul 07, 2022Prodigy
Check if the Synology QuickConnect feature is still enabled and that the ID hasn't changed.
PS also make sure you are on the latest firmware, and keep track of updates and when the device becomes EOL if you are going to have any of its ports exposed to the WAN. When the device no longer reliably gets security updates, I highly recommend disabling all remote access and then use the openVPN server in t he router to VPN into your home network and then access your NAS that way.
They use port 5001 for remote access which relies on their DS file app.
PS also make sure that you give the NAS a static IP, and if possible restart the router to confirm that it is properly assigning it the same IP each time.
