Axsom
May 15, 2022Follower
Ports 1 & 2 data flow is extremely throttled back
I have a Nighthawk AX120. Events leading up to this - will try to keep it as short as possible Everything was working perfectly, then I went out of town and came home to my apartment destroyed by w...
May 15, 2022Guru - Experienced User
It could be moisture got in in/on the board and is shorting something out.
Did you try a factory reset?
Did you try replacing the cables?
Try reinstalling the firmware in case something was corrupted?
