pillowfighter
Jan 09, 2022Follower
Ports not opening
Port forwarding worked fine on my Nighthawk R7000 but I'm having trouble with my new Nighthawk RAX30.
- My laptop has a reserved IP address. I have also used ipconfig to confirm that it is using this address
- I follow the instructions in the manual: navigate to Advanced > Advanced Setup > Port Forwarding / Port Triggering, select Port Forwarding radio button, click Add Custom Service. Then I create service name, select TCP/UDP, set the port number (same for internal/external), and select the device (confirming the correct IP address).
- This same setup worked fine on my R7000
- I've restarted the modem (Netgear CM1000), router, and laptop multiple times since configuring port forwarding
I have confirmed using multiple "pork checker" websites that the port is closed, and my friends are no longer able to connect to the games I am hosting. Please help. Thanks.
No RepliesBe the first to reply
