Dirtnapper01
Jan 12, 2023Aspirant
Power supplies mized up
In the process of setting up and moving the office around, the power plugs to the Netgear CM1100 modem and Nighthawk RAS49S router got mixed up. Both have same voltage, but the one of the plugs has a...
- Jan 12, 2023
Look at the back of each unit and there will be imprinted on the unit itself what the center pin is, Will show a symbol and points to the center pin next the the power jack in back.
Jan 12, 2023Guru - Experienced User
Dirtnapper01
After some very close inspection (as with a jeweler's loup) on the plug that I though was center neg, is - center pos; so, both plugs are correct. My error, thanks.
- FURRYe38Jan 12, 2023Guru - Experienced User
đ
