Dirtnapper01's avatar
Dirtnapper01
Power supplies mized up
In the process of setting up and moving the office around, the power plugs to the Netgear CM1100 modem and Nighthawk RAS49S router got mixed up. Both have same voltage, but the one of the plugs has a...
  • FURRYe38's avatar
    Jan 12, 2023
    Look at the back of each unit and there will be imprinted on the unit itself what the center pin is, Will show a symbol and points to the center pin next the the power jack in back.
