DonFoley
Dec 21, 2020Follower
Pre Installation of R6700AX WIFi6 router to an older NETGEAR C6300 cable modem
I wish to make the marriage of these two components as easy as possible. It seems to me that I should turn off the existing wifi router installed in the cable modem before plugging in the new wifi6 ...
Christian_R
Dec 28, 2020NETGEAR Employee Retired
Hello DonFoley,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
