hpw2408
May 19, 2019Apprentice
problem installing AX4 (RAX40). Cannot get to internet
Here is my setup before I touched it today. Comcast internet 300 MBS to Arris SB8200 Modem and then to R6300v2. Everything is great.
To "improve" things I did a straight swap of the R6300v2 wit...
- Jan 29, 2020Same issue. After reading how many hours it took experts to figure it out, I'm sending the POS back and exchanging for a different brand. My old TPlink is working fine, just wanted something faster, not a headache. Thanks
michaelkenward
Sep 18, 2019Guru - Experienced User
Daredevil77 wrote:
I have just had exactly the same experience.
Possibly, possibly not, given how many different "experiences" people have described in this six-month old discussion.
There is a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
The sort of missing information that could help people is the make and model of your modem.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
sgo
Jan 29, 2020Aspirant
