joanrogomes
Jan 05, 2021Aspirant
Problem settting up Nighthawk AX4 router
Hi, I was setting up a Netgear AX4 router and I'm experiencing some issues. I've setup my existing router to modem mode on its settings page and have connected it to the Netgear router with its ...
Jan 05, 2021Guru - Experienced User
What modem is this?
- joanrogomesJan 05, 2021AspirantIt is a Virgin media Hub 3.0
- plemansJan 05, 2021Guru - Experienced User
I've seen lots of issues on here with the vigin media hub 3.0's "modem only mode".
You can try putting the netgears IP address in the vigins dmz or try the orbi in access point mode with the vigin media in router mode.
- joanrogomesJan 05, 2021AspirantI'll try this later, thank you
