htanttila
Nov 19, 2020Aspirant
Problem with connecting WD My Cloud EX2 Ultra to Nighthawk RAX45
The NETGEAR Nighthawk AX6 6-Stream AX4300 WiFi Router is not listed in the above model number list, first off. Secondly, I had my WD My Cloud EX2 Ultra connected through one of the wired ports to...
htanttila
By the way, as far as experience goes, I am a retired Network Specialist.
Christian_R
Nov 25, 2020NETGEAR Employee Retired
Hello htanttila,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
