ArunGupta
Aug 17, 2019Apprentice
Problems after firmware 1..0.1.90
RAX120 After updating firmware to 1.0.1.90, I am seeing major issues. All my Wifi devices randomly disconnect from the router after few hours. Athough router's 2.4GHz and 5GHz LEDs are blinking, ...
roythk
Aug 18, 2019Tutor
i have same problem as you before.
then i am try to factory reset the router and set it up all again
untill right now anything working fine.
Maybe you can try to reset the router
- PistoleAug 19, 2019Guide
Here also wifi problems specially on the iPhone X. The wifi connection drops randomly and then I have to switch wifi off and on again to get it working again. On my Ipad Pro lesser problems. The connection stays on but sometimes I get the message that a page is not reachable and I have to choose it again. My Macbook Pro doesn't have any issues at all.
The Apple devices all connect through the 5GHz band and SmartConnect is on.
For the time beeing I have installed the previous firmware again, wich solved the problem. Definitely something wrong with this firmware!
- ArunGuptaSep 03, 2019ApprenticeI did factory reset and the router worked with new firmware for five days. Now I am on vacation and router has dropped all wifi connections. I have lost all security camera feeds and access to security system. Since the router is in AP mode, I can access wired devices only. This firmware is really bad. Not sure how much testing does Netgear do.
- avtellaSep 03, 2019ProdigyProbably also has to do with the fact that some of the issues maybe WiFi firmware related and so would require the actual chipset manufacturer to also fix issues that are reported by Netgear, Asus etc and other router companies to them as this is a brand new chipset and AX itself just entering the market.
