Whipsnade
Jul 01, 2024Aspirant
Problems setting up ReadySHARE with Password
I'm using an AX4300 (RAX45), firmware V1.0.16.132_2.0.92 and Windows 10 Pro 22H2, Build 19045.4529. I have ReadySHARE setup with a WD2001FASS 2TB HD. Works OK, a bit slow, but when I try to configu...
- Jul 09, 2024
This help any?
How long is the new password your using?
Any Special characters in the password? Try a simple basic password. No special characters.
Whipsnade
Jul 09, 2024Aspirant
FURRYe38, further update on ReadySHARE, after ranting about ReadySHARE possibly not accepting a complex admin password that did work for logging in to the router as admin I experimented with changing the admin pw to 10 characters, LC, UC & numbers but NO complex characters. This resolved the issue and I can now successfully map a drive to ReadySHARE. Still disappointed that I had to truncate my original admin pw but I'll live with it. I think I saw mention in another string that ReadySHARE is being phased out by Netgear. If true that's disappointing as I don't want to layout the bucks for a NAS. Thanks for the fix!
Jul 09, 2024Guru - Experienced User
Glad that worked.
RS is still in the new generation routers, RS series, so maybe still be hanging around.
I went NAS years ago. Have two now. Older units but works for my needs. Never looked back at anything else. Love NAS.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
