jmhga44
May 23, 2022Star
Problems with connection to work PC via gateway
I'm connecting from my home desktop to my office PC via a gateway and am having problems keeping the connection from dropping. I've talked to my Internet provider Spectrum and they do not see any pro...
jmhga44
May 23, 2022Star
Router - Netgear RAX50
Modem - provided by Spectrum (EN2251)
Firmware Version - V1.0.11.112_2.0.77
microchip8
May 23, 2022Master
Is the modem set in Bridge mode or router mode? If the latter, you're dealing with double NAT - https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
There should be only 1 router in your network. All others should be set in Access Point or bridge mode
- jmhga44May 24, 2022Star
I've only got 1 router..which is hooked up to the modem. The modem only has 1 Ethernet port and that goes to the router. I did hook the Cat 5 cable from my home desktop directly to the modem yesterday for a test (suggested by IP provider) and swapped them back..the problem didn't occur during the test and so far hasn't occurred after I swapped the cables back.
