1y0fms
Aug 29, 2021Aspirant
Problems With Web Page Rendering Since August Firmware Update
Ever since the latest frimware update, which I installed in August I have had web page rendering issues. Often I have to reload a web page 3 or 4 times to get the proper rendering. Often the web page...
- Aug 30, 2021
Try downgrading a version.
I've seen mutliple people with issues on the newer versions that have been fixed with a simple downgrade.
Aug 30, 2021Guru - Experienced User
1y0fms
Aug 30, 2021Aspirant
Your right. I did work. I had trouble with that firmware upgrade from the very beginning. It didnt install as they normally do. What a mess. I hadn't relaized at first that it was a problem. I had done a factory reset and the problem persisted. Going back to the previous firmware worked.
Thanks
