Cjkillian
Jan 31, 2022Follower
Product Difference RAX29 vs RAX30
What is the difference between an RAX29 and a RAX30? Thank you.
1 Reply
Look at the spec sheets on NGs web page to compare:
https://www.netgear.com/support/
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
