JayB_STL
Jul 28, 2020Follower
Proper RAX75 Router Settings
Hi all, I'm new here and I just got my router a week ago and it's a little shaky. The setup to replace my old router is smooth including the firmware update and the Nighthawk App setup. I just want t...
Christian_R
Jul 31, 2020NETGEAR Employee Retired
Hi JayB_STL,
If you recently purchased the device, I would suggest contacting our support team to assist with optimizing your router's settings. Newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
