Eric1361
Dec 11, 2021Aspirant
PS remote play - cannot connect to my PS5 outside of home
Hello, Can you please adivse how can I connect to my PS5 and desktop computer outside of home? It seems I need to do something on my router setting. Whenever I was trying to connect to my PS5 f...
michaelkenward
Dec 12, 2021Guru - Experienced User
What does that mean? I
f the PS5 and desktop computer are away from your home network, then you won't be able to use your Internet connection unless it is on a mobile network.
What Netgear hardware do you own?
What are you trying to do?
What are you doing and where does it go wrong?
- Eric1361Dec 12, 2021Aspirant
Hello, thank you for looking into this.
nighthawk AX6000 WiFi Cable Modem Router (CAX80)
I want to play ps remote play when I'm outside home through my ps5 in my livingroom.
I think my netgear cable modem router is blocking connection from outside of home.
In order to connect to my ps5 for remoteplay, I think I need to adjust setting so I can connect to my devices at home from anywhere.
